Results 1 to 6 of 6
Thread: Lack of Vacuum and Carb issues
    Ohio
    1985 Dodge Power Ram 50
    Last week my truck came back after getting the brakes redone by my mechanic. They ran diagnostics and found that I have a lack of vacuum, my carbs are out of sync, and the engine diesels hard on shutdown. What can I do to fix this?
    get a carb synchronizer gauge - you put in on the inlet to each barrel of the carbs and adjust the flow until they are drawing the same. I suspect your rear carb is drawing far less that the front carb and is causing all the problems. #4 cylinder is where the weber / mikunl intake pulls vacuum from, so check and be sure you have good flow.
    Portland, OR
    What pennyman1 said, there are many videos out there
    https://youtu.be/GaTRyHxvneY
    Ohio
    Thank you for the info, I've looked into getting an airflow tool and have watched a few how to's on the subject. Could this also be the cause of my dieseling issue? Or could I be running too high fuel pressure? (Holley Red electric fuel pump reg'd down to around 5psi)
    that is too high for the carbs - 3 - 3.5 PSI. Remember, flow is more important to webers / mikunis than pressure, but too much pressure will cause issues.
    Ohio
    Thanks, I'll reg that down next time I work on the truck.
