Results 1 to 7 of 7
Thread: coolant dripping of catalytic converter?
    midlothian virginia
    1988 Dodge Power Ram 50
    i have a 88 4x4 power ram 2.6 ...
    just got it a few weeks ago and have started to slowly replace little things here and there. but i have noticed my coolant levels dropping and today i realized there is coolant dripping of my cat? any ideas? thanks in advance!
    Lewistown, PA
    1984 Dodge Power Ram 50
    Dodge V8
    Either you've got a freeze plug leaking onto the exhaust (rusted/corroded through), or the head gasket is blown and it's pushing coolant into the cylinders. Remove your Radiator Cap, does it smell like gasoline inside the radiator? Next one would be to start the engine and watch for bubbles in the radiator. IF you can find someone with a Coolant System Pressure Tester, it would let you know if the system is maintaining pressure (and help pinpoint a leak if it's a freeze plug, radiator, etc). It can also be used to tell you if the system is over pressurizing.
    midlothian virginia
    thanks a lot! is the freeze plug easy to locate?
    and yes i can smell gasoline when i put my nose near the radiator with the cap off.
    Lewistown, PA
    Dodge V8
    If you smell gas in the radiator, it's a blown head gasket, possibly more (worst case scenario is a cracked or badly warped head)
    What was the out come of this????
    midlothian virginia
    it has been really rainy in va lately and the days it doesnt rain i have work haha...so still havent got in there to find out..i am ordering a webber carb sometime this week because i didnt want to deal with all the vacuum lines so hopefully within the next week or two ill get to it
    midlothian virginia
    So got the head off ... Head gasket wa blown badly and there was two cracks in the head! Not fun haha going to the junkyard this week!!
