Can anyone help me on how to remove the transmission on my 1989 mighty max step by step?
How can anyone not reply .Worthless people!
Automatic trans has extra steps on removing torque converter from flex plate. Should be 4 bolts. Remove before you remove the trans to engine bolts.
I don't have a fsm. Disconnect battery and remove started. Drain the trans, pull the drive shaft. Unbolt the shifter, remove the cross member and support trans with a jack. remove speedo cable, all ground wires. Remove trans to engine bolts. Support front of trans with second floor jack. Use pry bar to separate engine and trans. Lower floor jacks slowly. Clean all trans fluid that spilled on ground.
Not the best way to get help - criticism is terrible etiquette on any forum. We are here to help, but we expect respect. Do that again and you will be banned.
Follow this Link http://www.mightyram50.net/vbulletin...-Manual-inside
Download the Haynes Manual for the Truck. I've used it for 15 years...
Thankyou ..can thus manual also be used for manual mitsubishi mighty max?
Yes it can... it won't tell you how to rebuild one, that's a different manual, give it a look.
