Results 1 to 23 of 23
Thread: Tuning a 2.6L
    Rock Hill, SC
    The only ports I see and is available is the vac tree on the intake as you see are capped with vac lines looped over and the carburetor only has that port that the distributor is connected to. Should I connect the distributor to one of those ports on the vac tree on the intake and cap the carburetor port on the carburetor? what is a WOT?
