If you've got oil pressure issues, fragged bearings aren't going to help. This is one of those things where you won't know how bad it is until you've done a visual inspection and then it will be on you on the course of action. A big end or main journal bearing failure can cause catastrophic damage to the crank and/or rods. I think the oiling issues that plagued earlier 4G63 engines weren't an issue once they changed the head design, but it's still an engine. Change rings and hone the bores? - maybe. Bottom end bearings and crank inspection? - yeah, I personally would...and throw some new seals in it front and rear.
ok last question i should have for you for now, when looking on rock auto i see different rings like 0.020 over ect. which should i pick? I will link my RockAuto shopping cart and maybe get some pointers from you.. I just put "Standard" for all
My Shopping Cart!!!
