Results 1 to 6 of 6
Thread: 4d55 random power loss
    BC, Canada
    1986 Dodge D-50
    4D55
    Hey ,
    On my 86 ranger I occasionally have a loss of power and stall. Feels like air in fuel, and I put in some clear lines after fuel filter and before ip. No noticeable stream of bubbles entering, but when it happened today there was a definite air pocket in the line. Usually just takes 5 or so times starting it and dying then all the sudden it's fine. Recent fuel filter change. Weird how it's so random, hasn't happened in 3 or so months. Next thought is boost pump getting weak.
    Any feedback appreciated.
    Cheers!
    Inwood WV
    1991 Mitsubishi L200
    4D56-T
    possible if your fuel filter or pickup is clogging, it might be pulling air around the fuel inlet to IP at the hose clamp, in which case you wouldnt really see the air in the clear lines
    BC, Canada
    1986 Dodge D-50
    4D55
    New fuel filter just before this started so I wouldn't think its clogging. And what do u mean by pickup? I pulled off the line entering the IP, and turned the key to engage lift pump. It started pushing fuel but with pretty low pressure, like a weak stream just dripping out. Seems to me like it should be pushing a solid stream of fuel...
    Any reccomendations on pumps for these engines?
    Cheers
    los angeles
    1985 Mitsubishi Mighty Max
    4D55-T
    Quote Originally Posted by Jmuirhead9 View Post
    Cheers
    No recommendation here, because on the Mitsubishis, they don't even use a lift pump ... it all just gets drawn from the IP.
    Since you do have a lift pump, and it provides a weak stream.... well, that sounds kind of like a clog to me.... I wonder if you could turn the pump around and try to squirt fresh fuel back through the lines into the tank, just to see if anything gets unclogged?
    Inwood WV
    4D56-T
    Cheers
    Where the line picks up fuel in the tank, the pickup tube. It may be clogged
    Old fuel line is starting to crack and suck air.
    Check out the Fear Monger by
