Mr. Pennyman1;..... most interesting, look at the picts; definitely four headlights. I do not think anyone who could mount a shock upside-down would attempt a front facade change. Today I chased my dry metal-to-dry metal grunt again with no results. Occurs only after applying brakes and then goes away after awhile until brakes again. Driver's side, when the suspension works on a bump (lots of those in Eerie) or I spike the brakes to bounce the front end. Not the caliper, not a bushing I can see, not a ball joint, not the cross bar. I would suspect a bad shock, but it goes away after a couple minutes until I brake again. No check mark on my to-do list today!
