Glad to see all this little info coming out...hope this ticking goes away for you man...
keep posting guys im learning a little with each one...
Another option I use is to add Rislone to the engine oil - its a super detergent additive for oil that has been around since the 50's for these kind of problems. Had several AMC 6 bangers that are notorious for valvetrain noise that quieted right down with the stuff. Others on here tried it and got more power to boot.
Inactive
Any luck with those lifters? I have the same issue on mine, i can get them too quiet down for a little using Lucas Oil Stabilizer, but other than... no luck.... I even replaced the whole head and put new lifters, valves, seals, had it all machined, everything in there, and it still does it! Only when its idleing though. if i rev it or during normal operation it either gets quiet or just gets droaned out by the exhaust!... lol
Reason: added info
Nope, no luck. Mine gets louder as the rpms go up, its pretty damn annoying. Its kinda seemed as if my rocker arms on the 4th cylinder were a little wore out were the adjusters go. Might see if I can get some at the junkyard sometime and see if that will fix it. Other than that I don't know.
I've researched a bit on this. I didn't really like what I found but I can post it anyway. A few people added a bit of trans fluid to their oil as a cleaner. I would do this to my own car, just wondering if anyone else heard of this.
yeah 4doorciv...i have done that many times....i can remember my grandpa doing that back in the day..i guess it has gotten passed down...
works also..
well good luck man on this...the way these engines are they are just hassle and thats why i sold my low mileage swap a long time ago..
Inactive
you know i think i remember my Dad telling me about that a long time ago, and he is a mechanic, with his own shop. I never did try it though. I use additives in my oil, so i was afraid if i start mixing all that crap in the oil, they would have a bad reaction with one another or some crap.
