Results 1 to 7 of 7
Thread: 1988 Ram 50 load limits?
    Wautoma, Wisconsin
    I am trying to find out what the actual load limit is for a 1988 Ram 50 extended cab.
    It doesn't seem to come up in any of the spec info I have been able to find searching the web.
    Anyone know this off hand?
    Thanks
    Orlando, FL
    G64B
    the towing capacity is 3500lbs
    Wautoma, Wisconsin
    Thanks for that info, but the load capacity in the box is what I need to know.
    I need to deliver a 2003 Harley that weighs about 780 lbs. from Chicago to N. Georgia.
    Georgia
    1984 Dodge D-50
    4G63
    I've had my Harley in the back of mine.
    800 pounds isn't that much weight.
    I've also had mine loaded to the gills with dirt.....
    ~~~~~~My toys~~~~
    1984 Dodge D-50 (Daily driver, when raining)
    1990 Mitsubishi Mighty Max (Trying to figure out no power and sputtering)
    2006 Harley Davidson Heritage Softail (Rider when it's not raining and cold)
    1975 Honda CB750K5 (Rider when it's not raining and warm)
    1974 Honda CB350F1 (In paint for tins)
    1972 Honda CB175K6 (Just a rolling chassis, no engine)
    1972 Honda CB100K2 (Needs an engine, and rebuilding) (shhhh...if wife knew I had this, she be pizzzed)
    ~~~~~or headaches~~~~~
    Wautoma, Wisconsin
    That's what I thought, but wanted some confirmation.
    Thanks
    College Station, TX
    1984 Dodge Ram 50
    4D55-T
    I have definitely put more than 800 lbs in the back of my truck. The important thing is just to not push it too hard. I drove 800 miles with most of my life in the back of Wallace and just took it easy on the mountain passes. My bet is that given the route you're going, it should be relatively flat.
    1435 - 1600lbs capacity
