Will omitting the ERG valve effect engine performance with the Weber?
I'm going to give it another try on the fuel pump plate.
If it's a first attempt and this stuff is new to you don't give up. You gotta start somewhere (and anyway the first attempt is your prototype telling you where you went wrong so you can make the necessary changes to get it right)
If you delete the EGR valve on the inlet manifold it will require a block off plate. But even then that is only cosmetic really as the EGR valve will be non functioning without a vac line to actuate it.
