New Member S.C.
What's going on everyone!? I'm a new member to the forum. I have an 87 Dodge Ram 50 2.0!! It didn't come with lower steering so I purchased a setup to install it on my truck from a MM. I have everything installed except the fan pulley to change it from the single belt Ram pulley to the dual belt MM pulley.. Guess what it won't fit!!! I need help on the option to fix it.. Also any information on the 4g63 swaps would be great! I purchased a fully built motor 700whp I plan on installing so the more knowledge I can receive would be appreciated!! Thanks!!
Welcome to the forum.
Jump in and explore the forum and try posting your request in the gen2 area of the forum for a possibly quicker response. Ask questions and give answers is always welcome here.
Thank you for the advice!!
Welcome to the site, interested to see your swap being done.
This sticky should help you out: http://www.mightyram50.net/vbulletin...ap-information
Bachelors Degree
U have any pics? Im pretty sure my truck with power steering still uses a single groove water pump pulley. Water pump and alternator run on one belt and the power steering pump runs on another. Both belts then go on the 2 groove crank pulley.
I have a pic but idk how to post it here in the forum lol.. Either way if I try going around the water pump or under it my belt for the power steering is still hitting the fan pulley.
Could you post pics of the power steering pump , and the belt routing on the pulley?
