Results 1 to 8 of 8
Thread: Won't crank or start 85 MM 2.0 manual 2wd
    PORTLAND OREGON
    1985 Mitsubishi Mighty Max
    4G63
    I was spraying starting fluid around to diagnose high pitched noise suspected of being vaccum leak on weber carb, could not pinpoint location, turned off truck came back, no start won't crank no clicking at all. Battery newer and tested, in good shape, good connections. Push start didn't work, Any ideas would be greatly appreciated! Thanks!!
    Sounds like a ground issue somewhere.
    PORTLAND OREGON
    4G63
    Ok, good suggestion. I'm new to this vehicle, any idea where to look?
    PORTLAND OREGON
    4G63
    Good suggestion. I'm new to the mighty max, any idea where to start looking?
    I'm trying to remember if these have a ground wire to the manifold. If so, you might have gunked the connection by spraying. This is simply a hunch, and using up time until someone comes along with a decent answer
    PORTLAND OREGON
    4G63
    Solved Starter switch at the selonoid loose and fell off. Thanks for your help really appreciate the support.
    Foiled by a simple issue. Glad you've got it sorted out
    PORTLAND OREGON
    4G63
    Thank you, it had me absolutely foiled for a full day, maybe this post will help someone in the future...
