Hi, I would also like to see in real pics not just diagrams how the wires are all supposed to be hooked up!
You posted before that you've got a 1983 Mitsubishi pickup SPX, mine's a 1984 Mitsubishi pickup SP, so the wiring may not exactly match but maybe these will help you anyway.
I do have at least 1 wire that is not hooked up, no idea where it goes, came unhooked when I bought it & ran for the last year without it. I'd love to know where it's supposed to go.
Anyway, here's all I got, hope this helps some. Note the red line is a wire that is only taped off, not actually hooked up on both ends (may not be hooked up at the other end of it either, no idea. The circle may or may not be a wire, took the pics in the dark, put a circle there anyway just in case.
It's a work-in-progress, obviously:
IMG_4523.jpgIMG_4524.jpgIMG_4525.jpgIMG_4526.jpgIMG_4527.jpgIMG_4528.jpgIMG_4529.jpgIMG_4530.jpg
