Yea better off keeping away from a welder. You would need to fully clean out and allow to air out before attempting to weld. Welding rust holes sucks as well because the parent material is so thin that once you arc it ends up creating a hole twice as large. You then find yourself trying to fill larger spaces and creating all sorts of random shapes that never seal correctly.
