Results 1 to 3 of 3
Thread: Oil pan bolts/screws/?/?
    pa
    Trying to find oil pan bolts with no luck.. for the g63b 2.0.
    az
    Just about any type 6mm x 1.0 bolt will work. Ace hardware, home depot, Lowes should have them readily available. Most of the oil pan bolts are 12 - 15mm long the one under the timing belt is 10mm long. Or if you want do a search on line you can get a full bolt kits from street tuned motorsports, road race engineering, extreme psi, ffwd connection.
    pa
    Ok thanks just haven't pulled one and missing a couple . Thanks ..mikec
