Results 1 to 25 of 69
Thread: 93 Mm v6 4x4 has just given up on life
    Phoenix, AZ
    1986 Dodge D-50
    Quote Originally Posted by tink View Post
    You don't necessarily have to get it to run to read codes sent out by the ECU/ECM, just putting the key in the 'on' position can (not promising 'will') do the trick. For using the paperclip method the engine is to be left OFF. I had went thru this on a '93 3000gt & was able to figure it out by reading the long & short bursts on the analog meter. See: http://web.archive.org/web/201212011...codes91-93.htm for basic idea instructions BUT you will need to find the pins & fault codes that match up w/the ECU you are working with. Highly suggest letting it tell you whats wrong if it will rather than chasing a likely combination of issues. Good luck
    Thank you sir! this is awesome i was looking so hard for a chart that shows just this a couple days ago!! Now i just need to go buy a analog multi-meter. But i just ripped the front of the engine apart and checked the timing and it looks like everything is on point and the belt doesnt look to bad i suppose it has been done in the past 20k or so.
