Could you post the picture of the method?
Or you can take and cut / grind off the stock cable connector from the old carb. Then with some care you can place it on the new carb in the correct place so you can get WOT with out bending the linkage. Then you don't need to cut the cable end off.
I will see if I can get Mopar JA to send me a picture of it. That's if he still has the carb.
