Results 1 to 7 of 7
Thread: weber carb
    deland fl.
    weber carb
    Where have you guys got your webers from I don't want to make the mistake of buying a fake I have a 1988 2.0 g63b
    pa
    http://www.piercemanifolds.com
    www.redlineweber.com.
    This is where I bought mine .It's through pierce manifolds eBay id . You might want to call them direct and get the hanging throttle linkage bracket apose to the boomerang bracket that comes with the kit generally.
    pa
    manchester ky
    purchased mine on ebay, and like the other guy stated I would definatley get a bracket , I had to cut the one supplied up and make it work , other then that it was smooth as silk and a great carb. until I found out my intake was busted and cracked
    Or you can take and cut / grind off the stock cable connector from the old carb. Then with some care you can place it on the new carb in the correct place so you can get WOT with out bending the linkage. Then you don't need to cut the cable end off.
    I will see if I can get Mopar JA to send me a picture of it. That's if he still has the carb.
    Check out the Fear Monger by
    deland fl.
    Well still haven't got around to buyingthe Weber can't seem to save the money but does it matter if I have a automatic
    Portland Oregon
    Could you post the picture of the method?
