Hydrocarbon Terrorist
On the flip side, (not that grounds are not a huge issue),
Whitey ('91) was giving me fits with an intermittent 'click click click' no start...
( pulled starter & bench tested, ck'd clutch interlock, relay ck, etc...)
Fix was cleaning the oil off of the solenoid signal connector.
Oil leak was repaired, forgot about the follow up !!! DUH !!!
