ok, so these pics suck but if you look closely enough you can see they will not work because the mounting pattern is flipped. they both mount to the outside of the frame, everything else is identical except the mounting.
this is the 95 2wd box
this is the 87 4wd box
it could easily be fabbed but probably not what you were looking to do.
