Results 1 to 2 of 2
Thread: Vacuum advance after weber install
    West Columbia, SC
    1984 Dodge Power Ram 50
    Hey Guys curious about the vacuum advance after installing a weber 34/34 (im getting ready to install a 32/36 figured id go ahead and ask the question) there is enough vacuum on the distributor to almost fully advance the timing at idle should i set the timing with the vacuum line hooked up? also how much timing are you running on your G63B 2.0? any comments welcome!
    Be sure to use the ported vacuum to the advance unit - its located above the throttle plate. Run 7-10 degrees BTDC then adjust from there.
