Results 1 to 10 of 10
Thread: 91' Mighty Max Dash lights?
    Chaparral, New Mexico
    1991 Mitsubishi Mighty Max
    Can anyone tell me what all of the dash lights are supposed to be on a 1991 Mitsubishi mighty Max?
    NC
    1993 Mitsubishi Mighty Max
    Here's from my '93 manual. I imagine it's identical!
    Talking
    Thanks! I've needed that for so long! I needed to see if there aren't any lights being used so that I can install a door ajar light. By any chance, do you know how to hook up the buzzer that's mounted underneath the dash for the door?
    NC
    No problem!
    Funny you ask that. I wanted to enable the buzzer and found that it was unplugged and thought, "Well, that's just too easy" and sure enough I was right because it isn't buzzing. Haven't gone any deeper. I'd be curious to hear others experiences about it.
    I think the buzzer was for if you left the keys in the ignition or left the headlights on and opened the door.
    My problem is that I cant find a connector to plug it in to.. Any Ideas why?
    Thanks! Didn't know that. But mine doesn't have a wire that I can connect to so I don't know how to connect it... Unless its hiding
    San Jose, Costa Rica
    Nice, guys where's located the buzzer?
    And pics please
    The buzzer is under the dash on the drivers side up in front of the kick panel and towards the firewall. All the buzzer plugs into is the little plastic housing that is mounted on the cab wall, it will buzz if the keys are in and the door is not shut all the way I believe.
    Any pics showing how it looks?
    There's a yellow wire disconnected coming From the driver's door dome light switch.
    Also near the fuse box There are 2 Green/Orange wire disconnected.
