Results 1 to 5 of 5
Thread: 4D55 piston protrusion
    Seattle WA
    1985 Dodge Power Ram 50
    4D55-T
    Hi guys (& gals?)- Been "out of the loop" for awhile, but now I'm crawling back for guidance:
    I've just partially completed a 4D55 block rebuild using ITM .020" pistons. Installed #2 and 3 piston/rod assemblies, and it looks like crown protrusion is running about .065". YIKES! Is that TOO MUCH? Can't seem to find the correct specs anywhere.
    Burbank, CA
    1983 Mitsubishi Mighty Max
    4D55-T
    I will look into it for you but I NEVER had a good set of ITM pistons as all once running made clanking sounds from valves touching piston. No not enough to lock up but enough to make a knock and cause you to dremel the pistons where the valves sink in.
    Seattle WA
    4D55-T
    Quote Originally Posted by mikewarme View Post
    HMMMM... Did you have this same issue with more than one set of these? I wonder if maybe the pin bore is machined a little too low, causing the piston to ride higher.
    Burbank, CA
    4D55-T
    With maybe 5-6 sets. There answer to the problem was to discontinue making them. Bunch of assholes with their taiwan crap
    Seattle WA
    4D55-T
    ANYBODY.....piston protrusion........anybody........?
