Results 1 to 3 of 3
Thread: Sound systems
    Wichita Falls, Texas
    1991 Mitsubishi Mighty Max
    Sound systems
    What are you guys doing for your sound systems? Are you just running 4s in the stock positions with a shallow sub and amp behind the seats or are there other places to mount speakers? Can the stock locations fit anything other than 4s? Also it would be nice if you could add what brands and models you are using.
    Currently i have everything stock in the interior with only one speaker working so its definitely time for an upgrade.
    Jacksonville, FL
    G54B-T
    You can put 6x9 in the b pillar. Just gotta cut holes in the cab. Ive got a pair of 10 inch subs behind my seats but that only works for me since Im short. Amps are under the seat. You can probably upgrade the dash speakers. I just put tweeters in the dash and cut holes in the door panel to put speakers in the door.
    I have 4" in the dash with tweeters at the top of the a-pillar and 6.5" mids in the b pillar in my ext cab, with an amp under my bench. Plan on throwing another amp and two eights or a ten in there in the future.
    Josh
    09 BMW 335i E92 Twin turbo
