Results 1 to 3 of 3
Thread: Cam Sprocket Bolt
    SilverLake Washington
    Cam Sprocket Bolt
    I am in desperate need of the drivers side cam sprocket bolt. I bought a 1990 mitsu max with a 3.0 which the pervious owner had decided to take the top end apart for some reason. I have all of the parts and bolts for everything but that one bolt LOL. I am not sure but i think it is reverse threaded. Its dark right now and i am mad so i havent got a chance to tell. If anyone has one or if it is regular threads the thread size and i can get one. I am at my wits end with this little basket case. email me at thedude055.mm@gmail.com with info or message me here
    Vanessa, Ontario
    1989 Dodge Power Ram 50
    You could try the bolt from the other sprocket to see if they are the same. Both camshafts turn the same way so the threads will be the same direction for both. If the bolt fits, take it to an automotive parts shop and see if they can match it or try a local auto recycler.
    Thanks andy that is exactly what i did. I got it now just to get the timing actually right lol.
