Whoa, it is definitely a family member! You can get a bit of adjustment off the bracket that the small tensioner spring gear is mounted to. But if it takes more than that be warned - taking apart the whole mechanism takes some muscle as the main loading spring is really strong. It'll bite off a finger if you're not careful...normally it only takes bumping the small tensioner gear a tooth to set it right. Good luck!
