Oil leak, what is the ultimate fix, replace seals in oil pump?
Hi all,
I have a 93 mighty max 2.4L. It has been running great. The only issue is the oil leak...It has 200k miles on clock but still drives great. I have new water pump, timing belts, valve stem seals and lifters in place..The clutch was replaced only 30k miles ago...It is just a little too early for a full overhaul... However I am so tired of oil leak... I replaced valve head gasket and put RTV over it, I am pretty sure now it is not the leaking source... But I still see oil leak....
I am thinking .. it must be the front case / oil pump seals. Is it difficult to replace them while engine in the car?
