Results 1 to 4 of 4
Thread: Drop Spindle Question
    Austin
    1991 Mitsubishi Mighty Max
    4G15
    About to buy drop spindle and I found some that state the info below:
    Fits: 1979-1986 Mitsubishi Mighty Max (2WD)
    Question is will these fit a 1991 MM? I know the ones that airbagit sells state that there will fit 1987-2006, so I am assuming the the drop spindle is the same for all MM.
    The reason I am looking at these are they are about $50 bucks cheaper and are made by Hot Rod
    the spindles will fit from 1979 - 1996 2wd trucks - the major difference with the spindles is the position the caliper sits on the spindle. All the drop spindles I have seen are setup for the 87-96 style caliper mount. They will work with the 79-86 calipers, but the dust shields need modified for the calipers to clear on the spindle. The only spindles currently made are airbagit/ aim industries.
    Austin
    4G15
    chassis tech is aim industries - look on airbagit site - they are the same spindle.
