Haven't really done anything with the truck in awhile but just drive it. While at the junkyard awhile back I found a remote oil filler cap assembly from a V6 montero, so after 5 years of doing the swap, I finally have and easier way of filling the engine with oil. With the top mount IC, I had to remove the intercooler every time I needed to add oil, since the original oil cap sits under the TMIC. I just had to weld a bracket for the oil cap and a nipple to the mechanical fuelpump blockoff plate and just connect a rubber hose. This mod will makes oil changes so much easier.
