Results 1 to 25 of 120
Thread: Weber install questions 2.0 G63B
    Georgia
    Got it all buttoned up and it started on the first try!!!!!
    Now there's this weird high pitch squelch/squeak that remains constant at idle and fluctuates by throttle. It sounds like a massive air leak....don't know if this is normal.
    There's a couple things that I'll add later with pics in reference to the wiring .
    Georgia
    To clarify: The two black wires are the ones that you want to use for switched power
