Results 1 to 25 of 120
Thread: Weber install questions 2.0 G63B
    Georgia
    I grabbed some of that permatex high tack and now im waiting on the new gaskets to come in. Im going to let each layer set up a bit before adding the other layers. This includes the mounting studs with the loctite.
    I swear I did everything by the book when I installed it and couldnt figure out why I had that leak.
    Hopefu;lly the warmer weather combined with letting each section set a little will help.
    Thanks for all the responses and suggestions!!
    clarksville, arkansas
    1988 Dodge D-50
    Quote Originally Posted by unc25 View Post
    i was glad to read i wasn't the only one that used loctite on the mounting studs.
    i was kind of worried over that one after having to redo everything yesterday because i developed a whistle and found out that the whole carb was lose .
    then like yourself unc25 i made the bold move and put some loctit on the studs .
