Geez, you should take those oil pump mods and pics you did from photo bucket and post a separate How-to in this section. just a suggestion.
Hell dude, the rate I'm going I'll end up with a whole site just on building a bomb resistant G63B hamburger with everything! So far I don't think I've done anything new or special, just the fact I've decided to give it a shot myself. I was scared of carbs once and thought they were full of dark magic - then I started tricking them up and derestricting them. I still haven't done a full short block rebuild by myself so putting the '63 back together will be a little nerve wracking. This however is the first carb retrofit I've tried so I have no benchmark to compare with (and using a carb that nobody seems to be familiar with is not helping either! lol) I really wanted to try a quad rack of bike carbs but that will take some fabrication work that is out of my league - at least for the time being. Once I have the mechanics of the install sorted I'll have to design a filter and air intake set up that will suit the Weber. More work...
Just means you will be Master Builder when your done.
