Results 1 to 4 of 4
Thread: 92 mightmax
    lexington, nc
    92 mightmax
    I have a 92 might max with 2.4 motor in it started spiting an spudering so I changed fuel filter drove it for a day an started the same thing again anyone have any ideas beside fuel pump plugs an wires less then a year old
    Richmond, CA
    Visually and physically feel every single vac line for cracks and splits. Use the diagram on the underhood label. Check the O2 sensor and air filter, too?
    "Keep 'em on the road."
    See what I have for sale:
    http://stores.ebay.com/zims
    Spray WD40 around inlet manifold gaskets, vac lines - anywhere suspect as noahwins has suggested. If you get a change in the way the engine runs - you found your issue.
    Georgia
    1984 Dodge D-50
    4G63
    Check your spark plugs for wetness and fouling.
    Also what kind of wheels are they?
    Can you show some more pics of them and your truck?
    Thanks man.
    ~~~~~~My toys~~~~
    1984 Dodge D-50 (Daily driver, when raining)
    1990 Mitsubishi Mighty Max (Trying to figure out no power and sputtering)
    2006 Harley Davidson Heritage Softail (Rider when it's not raining and cold)
    1975 Honda CB750K5 (Rider when it's not raining and warm)
    1974 Honda CB350F1 (In paint for tins)
    1972 Honda CB175K6 (Just a rolling chassis, no engine)
    1972 Honda CB100K2 (Needs an engine, and rebuilding) (shhhh...if wife knew I had this, she be pizzzed)
    ~~~~~or headaches~~~~~
