Quote Originally Posted by randyrr View Post
I have a 2wd 91 dodge ram 50 with the 2.4l engine and stock 5 speed transmission.
Will a 2.0 engine from a 88 mighty max bolt up to the stock transmission that came with the 2.4 l engine?
What about motor mounts, will a 2.0 engine bolt up to the stock motor mounts in a 91 dodge ram 50 ?
when you did this swap did you swap the injection over or run a carb on the 2.4?
