Results 1 to 9 of 9
Thread: 1988 Mighty Max 2.6l 4x4
    Ramstein, Germany
    I am wondering what engine and transmission I have and where I can buy an idler pulley. I am located in Ramstein Germany and my truck is in Florida which I will be back with in a few months. Other ideas that I would like to learn about would be to install a turbo diesel in it one day. Any help is greatly appreciated
    ebay has the pulley, or rockauto. You can also use one from a conquest / starion motor - they are also 2.6 motors
    Ramstein, Germany
    I checked rockauto and it did not come up with anything. found it weird that I could not find it
    Ramstein, Germany
    Thanks! I am at work so I can not check ebay just yet. I will do it when I get home in the morning. This link is for the 2.6 1988 mighty max idler pulley?
    You have the g54b motor, the transmission is probably KM145?, should say on the plate on the firewall when you get back to your truck. Not sure that your 2.6 has a timing chain idler pulley that can be replaced, I don't remember one when I redid a bunch of stuff on my old 2.6.
    Ramstein, Germany
    Thanks for the help! When I get back Stateside I will check it out. I would like to switch out the engine with a Turbo Diesel but I am thinking that will be more of a hassle than it's really worth. Once again thanks for all the help and info!
    Ramstein, Germany
    I just bought that idler pulley off ebay. I am really grateful for the help from this forum. Thank you for taking the time to help Pennyman
    Not a problem -if you have any more questions, don't hesitate to ask.
