Results 1 to 10 of 10
Thread: map sensor
    Bothwell,Ontario
    map sensor
    Doesn't the 2.4 Efi use a map sensor with the Air flow sensor and the intake air sensor?
    I though the worked hand in hand to adjust trim...
    It is not listed in the service manual
    you either have a map or maf - not both. There is not a map to find on a maf setup motor - the ecm determines the operation of the motor based on the input of the map or maf sensor. some motors work better with one type over other - people switch out fords from maf to map, gms from map to maf
    Las Vegas, NV
    1991 Mitsubishi Mighty Max
    There is only a MAF on this truck. Many later Mitsu engines used both, but it wasn't until around '96
    I stand corrected - but I was right that the 91 did not have both.
    Bothwell,Ontario
    Thanks for the response. ...I thought most used both for fine tuning if the trim.
    Orlando, FL
    G64B
    I have seen 96 mighty max has a map sensor on the intake plenum and maf sensor like merrill mentioned. here is the picture i have of it
    Bothwell,Ontario
    Can you put an arrow to the map sensor? That looks identical to my 91 engine
    Las Vegas, NV
    Top right of the pic on the intake manifold.
    Trust me, you don't have one unless you have a '96 model year.
    Bothwell,Ontario
    So if I get a 96 computer I will need a map sensor?
    Las Vegas, NV
    Yes u less you intend to tune it out somehow.
    I don't suggest getting a '96
