Sophomore
2.0 oil pressure sending unit location?
Could someone tell me where the oil pressure sending unit is located on a 1988 Ram 50 with a 2.0 motor?
Its on the oil filter housing.
Sophomore
I just changed the oil and filter and didn't see it.
I will look again.
Sophomore
Well that helps a lot! That has to be one of the cleanest motors I have seen in a long time.
Thanks
Sophomore
I found it, but I had to remove the stone shield or what ever that plate was for covering the bottom of the motor.
