Results 1 to 3 of 3
Thread: Does anybody know what I need to fix this grill?
    big rapids mi.
    I just got my 85 ram 50 home from out west and notice the bottom of the grill is loose. It looks like clips hold it in on the bottom. Does anybody know where to get these clips or how to fix? Thank you in advance for any info.
    Go to a body shop and show them. They will be able to find something that should work. I just use a cable tie. But my old part was like a plastic rivet.
    You can try modding those press in nylon body lugs to the frame work behind the grille and using phillips head screws to anchor the grille in place. It's a permanent fix but the grille will bust off from these points if you take a hit from the front.
