i haven't removed the shifter or adjust the clutch yet. I'm planning on doing it on Monday. The clutch seems to be fine. I mean sometimes I have the press it all the way down before I have no resistance going into 1st gear. Even with some resistance going into 1st gear, it doesn't grind at all. I have also noticed that when I start the truck in first gear I can shift to reverse without a problem, it will only grind if I had drove it for a while.
