Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: Insturment cluster change out?
  1. #26
    pa
    Has anyone already done this that has a good diy for A 2nd gen? Also anyone know what the black switch is on the bottom right of the cluster ? Thanks.
  2. #27
    pa
    Volts, fuel, oil, gas all work . Having trouble with Speedo , tachometer < haven't hooked up yet . And back lighting.
  3. #28
    The black switch is to reset the "service engine" light that comes on every 60,000 miles, to remind you to change the timing belt. Clicking it a few times won't hurt anything.
    There are connections on the firewall for the tach, though I am uncertain how to connect them.
    I have not made this upgrade yet, but I've kept my attention on those who have (for when I finally find a sport cluster). I DO know the oil pressure sending unit needs to be for a gauge and not a light.
  4. #29
    Missouri
    4G61
    Can you show where you hooked it up at the coil?
  5. #30
    Tach signal would come from the white wire attached to the coil (-) terminal, so maybe you can trace it back from there.
