Results 1 to 10 of 10
Thread: grille, headlight bezels, bumper questions
    North Greensboro, Nc
    1987 Mitsubishi Mighty Max
    So looking for some parts but alot of places are saying 87 front end has different mounting points for grills, headlight bezels, and most importantly the swap from steel front bumper to the plastic bumper cover i want so bad for 60 bucks on ebay right now. I know i can make them work but I just find it weird more than one vendor doesnt suggest those parts..
    thanks!
    *edit: forgot to mention that most of the parts i have found are labeled as 90-91-92.
    They will all fit just fine on your 87. If you look in my thread you will see I have all 93+ stuff on my 89 front end. For the bumper you just have to get the three front brackets; the reinforcement bar and two front brackets(although I've never had these two). The side brackets are the same(or atleast work) from the 87.
    Josh
    09 BMW 335i E92 Twin turbo
    awesome, thanks for the info placing order now. most of the brackets. just wasnt sure if the rad support was crazy different or anything
    There are a few little differences but nothing that will keep the parts from bolting up like they should.
    Josh
    Could you link me to the correct parts? thanks
    I put a 95 grille on my Dad's 1988 Ram 50 without any trouble. The plastic bumper cover can be made to work on the 87 bumper with some minor mods.
    This had front end damage prior, all brackets, steel bumper and valance are garbage. I had do some rough love and chain winching to get front frame horn straightened out. All good now just starting from scratch for mounts though.
    What parts do you need links to exactly?
    Josh
    anything that holds the front bumper on. I think i was able to salvage the side brackets but the fronts are toast. hard to source parts when its a 87, 92+ bumper with nothing to go by.
