Results 1 to 4 of 4
Thread: Vaccuum line from the timing advancement unit - 2.6L
    Apex, NC
    1987 Mitsubishi Mighty Max
    Noticed today that there is just no hose on my timing advancement unit. Where is this hose supposed to run to? Is it weird that I dont notice any issues driving the truck?
    Vanessa, Ontario
    1989 Dodge Power Ram 50
    It should go to one of the ports just above the throttle plate on the drivers side of the carb. It should be teed with a line that runs to the thermo valve. I think there is a three port rubber connector that plugs into the carb. If you check the wiki section I've posted some vacuum diagrams. After you get it hooked up you may want to double check your timing advance. Should get better fuel economy after.
    Quote Originally Posted by Andy 2 View Post
    I second this. Thanks for the Wiki addition. This is a big help. God knows how many times people ask for this .
    Find me on FaceBook
    http://mobilemillwright.com
    Vanessa, Ontario
    I somehow posted those twice. There are only supposed to be 3 diagrams. I can't remove the duplicates.
