Is the rear main held onto the block by 2 small studs and nuts?
Or are you talking about the flywheel bolts?
Associates Degree
This is what I'm talking about . The bolts surrounding it what are ylthe torque specks so I dont over or undertighten them.attachment-3.gif
Sophomore
5 bolts with 10mm heads right? 8ft-lbs I think but wait for someone else to confirm, I will pull out my manual tomorrow to double check.
10 Inch pounds not foot lb's. Just nice and snug with a 1/4" ratchet is fine. It's not that critical. Use silicone everywhere except on the seal.
Associates Degree
Ok 10 inch pounds us what I went with and used( arboiatic)sp? sealer around the inside of the gasket As the Manual shows. . Thanks.
