Results 1 to 19 of 19
Thread: gas leak help before i blow up
    deland fl.
    So everytime i shut my truck off gas spills out from under my truck it looks like its coming from the fuel pump. Has this happened to anyone else? To get the truck to not spill has i have to hurry out of the truck and take off the gas cap i guess to release the pressure?
    You can always check by placing a paper towel under and then run it around the block and shut it off. Then look to see if it's leaking.
    Reno
    God thing you're not a smoker lol
    your gas vapor canister is not venting properly - check it out
    deland fl.
    How would i check the canister?
    there is a purge valve that is vacuum operated on the canister that vents to the carb and air cleaner - check it for proper operation. Also pull the canister out and check the filter on the bottom - if it plugs up it won't breathe and vent the tank.
    deland fl.
    Should there be a hose connected to the bottom?
    deland fl.
    Can i drive with out it on?
    you can drive with it disconnected - many vehicles have the canisters missing because of these issues. Just be sure to plug the small vacuum line to the purge valve to prevent a vacuum leak
    deland fl.
    Is that the line that goes to the carb?
    if its a large hose, no. How many lines are there on the canister?
    deland fl.
    3. One says tank one say carb other says ac
    Pull the tank one and leave open, if that does not fix the problem, replace the filler cap.
    deland fl.
    I already replaced the filler cap and pulling the line didnt work neither did taking the whole thing o
    deland fl.
    Do i just need the pump? Is there a vent in the tank?
    pump is all that is left - tank vents through the canister.
    deland fl.
    I know this is late but replaced the pump last month and no more issues. The truck even runs better now that it get the right amount of fuel to the carb
    Quote Originally Posted by woody__65 View Post
    Didn't I say something about that way back when. So I guess that's where the gas was coming from.
    deland fl.
    Yes you did camoit but I could do it at the time and then more important re pairs came up I had both front cailpers lock up on me while I was on the other side of the state and then my alternator went out but I finally got the truck running perfect now it's time for the drop blocks and a new bed.
