Results 1 to 9 of 9
Thread: What is this between grill/radiator?
    El Paso, Tx
    What is that thing bolted to those two aluminum plates? Also does someone have a picture of what this is suppose to look like, doubt those aluminum plates are stock.
    FL
    May be a horn?
    That shouldn't be there, only thing that would be in that spot besides the radiator would be the a/c condenser(If you have a/c) which sits on the front side of that opening. Probably a horn or something like maddmax said.
    Josh
    09 BMW 335i E92 Twin turbo
    Definitely not stock, and it sure looks like a fan motor, to me.
    Unplug and remove it. If California falls into the ocean, you'll know the part was necessary. If not, you lost nothing.
    Las Vegas, NV
    1991 Mitsubishi Mighty Max
    Look at the info on the sticker, Google it, find out what it is.
    El Paso, Tx
    So junk pile for that thing it is, Thanks guys.
    Oakland, CA
    Auxiliary fan. See ghetto rigs like those pretty often at work. Toss it, do the cooling system right instead of band aids like that.
    Mississippi
    1980 Plymouth Arrow Truck
    Can you trace the wiring to see where it goes?
    sheffield, vt
    1978 Dodge D-50
