the trannies in these trucks are not computer controlled - the issue is the temp sensor on the intake manifold next to the throttle body. Take the black wire connected to the sensor and connect it to a ground lug on the intake maniford and the O/D should work all the time unless you push the button on the stick to lock out O/D. The temp sensor grounds the O/D solenoid when the truck is at operating temp for emissions reasons.
