Hi guys, so I've done this complete turbo setup on my
truck. Runs really well but it's only boosting 1-2 psi.
Turbine housing is .63 on an 8valve 4g63. Possible i
went to large on the turbo?
The size of your turbo isn't the problem. Have you done a boost leak test? What type of wastegate setup are you running?
Excuse me, 4g64. Stock motor in the ram. I haven't done a boost leak check
the is pretty new, all the couplers seem tight. What would u suggest?
8 Valve 4G63? in a 93?...yeah, check for boost leak, I'm running anywhere from 25-30lbs boost .82 trim on a PTE 6262.
ITs a 4g64 excuse me. But I see yours has a massive turbo
but in stock form you think it would spool it
Your 4g64 should be able to spool that turbo almost instantly. Either you have a massive boost leak or possible issues with what ever wastegate your running.
It was the cheap ebay wastegate. I bolted a bare dp flange on and
it boosted up almost instantly. Get what you pay for![]()
it still runs terrible with any boost. Detonation at 3psi
Premium Fuel, also what are you using for Fuel Injection Control, you need to get rid of the MAF and go speed density with a aftermarket ECU on the pressurized side of the intake.. The MAF doesn't see the boost, it's in front of the Turbo, and it controls the amount of Fuel, you are way lean. What size injectors are in it? stock 275's? have to be AT LEAST 450's. I assume an Intercooler?
tell me more...
as of right now all the fuel system is completely stock. i have 450cc injectors to put in a long with an safe. my problem i don't have a wide band yet so i really have no clue on setting up a base map on the safe. id love to install it though. and yes, I'm pretty positive its super lean. 2 psi and its hoping and sputtering. I'm not trying to build a race truck.. just a simple 8-10psi cruiser. I've also looked into an e manage like greedy. any idea what i should set my ignition timing at?
yes small front mount
Probably have way too much timing advance as well, n/a timing tables are way way too aggressive for a turbo application.
Do you have a wideband? If you don't that should be the next thing you get. Can't get a custom turbo setup running good without no way to monitor your air/fuel ratio.
safc's are garbage to tune with, but if its all you have it can work.
You can either pull 10-15 degrees from the cam/distribtor(not sure which one you use) or you can run static timing by locking the cam/distribtor and setting it at around 10-15 degrees advanced. Both are gonna cut your fuel mileage quiet a bit. Since your timing will be set up for WOT full boost, your gonna loose alot in your cruising and idling which will reduce efficiency.
Chances are the truck is building boost while its still in closed loop. So your gonna want to disable closed loop and have the truck run in open loop all the time. Just unhook o2 sensor to accomplish this.
For your fuel system, your gonna want a high flow high pressure pump and an adjustable fuel pressure regulator.
You'll use the safc in combination with the adjustable fuel pressure regulator to meet your fuel demands for boost. You may have to drill a few holes into your maf to allow extra unmetered air in to get your crusing and idle a/f ratios to an acceptable level.(due to the increased fuel pressure and flow)
Boosting on the stock ecu is a pain in the ass and you loose quiet a bit of mpg's but it is possible. Going standalone is a way better option if its in the budget.
no wideband yet. the only thing I've done was put in a 2g turbo maf...
i just want the truck to run good on 5 psi. i have no clue where my ignition timing is but either twist on it still runs awful
Go back to the stock maf. The 2g maf has no place for you to drill holes to increase the unmetered air flow.
If you want it to run good, either go stand alone or find a turbo ecu for it. As long as you stay on that n/a ecu, the most you could ever hope for is it to be able to run without blowing up.
I've been a honda guy my whole life. my last turbo civic made over 500whp uncorrected. I've even had 400 whp 2g gsx.. I'm not new to the tuning world but this truck is something else... having a hard time ;(
a turbo ecu requires coil packs... my truck is distributor
I'm almost considering an fmu for now.. I'm lost on this thing
I had a hard time tuning my 4g37 thats fuel injected when i went turbo. Took me a while to figure it out. But after hooking up to the stock ecu and logging it i found out the ecu has a maf cap and injector duty cap. The ecu ignored everything over around 800hz. My safc would show max hz readings of around 1800-2400hz . Also no matter what i did injector duty never went much passed 50%. And then i saw that my timing was around 33 degrees advanced during wot. Also the ecu staying in closed loop even when in full boost, if it was under 4krpm. So if the ecu on your 64 is anything like a 37, it sucks a big one.
