Results 1 to 5 of 5
Thread: Installing rollbar lights any advice?
    Reno
    Thank you all for the information needed to restore this little beast. Three more major projects but any ideas on how to installed lobar lights? The wiring diagram is blah.
    sheffield, vt
    1978 Dodge D-50
    i drilled holes & ran the wires thru the inside of the bar. tack welded bottom of each thread so no-one could steal my lights easily. as for wiring you should use a heavy duty relay (i use a 100 amp)...a search online should produce a diagram...concentrate on very good grounds...i ran an extra ground to the frame.
    use a fuse... :-)
    look into putting a higher output alternator on if you are running halogen lights, or you will kill the battery quickly. Factory alternators are only 45 amps - get a 75 to 100 amp one from a starquest or expo van.
    Reno
    Got some LED fog lights and was hoping to get an LED bar to avoid using more output than I should. Light bar will come last I far the fog lights don't look bad. Have to repair front end since it's a safety issue.
