Results 1 to 6 of 6
Thread: New owner from AZ
    Mesa,Az
    New owner from AZ
    Picked up 2 mighty maxes over the last couple of months. One is a 92 macro cab and the other 94 MM. Planning on using the 94 as a parts truck for the time being. The macro cab engine is in its last legs, compression is around 105 psi on all cylinder with the engine warmed up.
    Mesa,Az
ID:	13957Click image for larger version.
ID:	13958Click image for larger version.
    Columbus, OH
    you may have 2 variants of the same engine, the 4G64. depending on the build date (April/May) of the 92, you may have a 6 bolt 4G64 or a 7 Bolt 4G64, referring to the number of bolts on the Crank for the Flywheel. not everything engine wise will transfer between the 2 models.
    http://www.vfaq.com/mods/early-late-engine.html
    arizona
    1984 Mitsubishi Mighty Max
    4D55-T
    hey, I'm also in Mesa and have two trucks. Welcome to the board.
    Georgia
    1984 Dodge D-50
    4G63
    yep, I got both........too bad I still need a new engine.
    ~~~~~~My toys~~~~
    1984 Dodge D-50 (Daily driver, when raining)
    1990 Mitsubishi Mighty Max (Trying to figure out no power and sputtering)
    2006 Harley Davidson Heritage Softail (Rider when it's not raining and cold)
    1975 Honda CB750K5 (Rider when it's not raining and warm)
    1974 Honda CB350F1 (In paint for tins)
    1972 Honda CB175K6 (Just a rolling chassis, no engine)
    1972 Honda CB100K2 (Needs an engine, and rebuilding) (shhhh...if wife knew I had this, she be pizzzed)
    ~~~~~or headaches~~~~~
    El Paso, Tx
    Is that a 1g steering wheel i see. Thanks for the idea. My mm needs a new horn piece, but i got a spare wheel from a 1g.
