Results 1 to 7 of 7
Thread: I need some advice for a lower control arm.
    Los Angeles, CA
    1991 Mitsubishi Mighty Max
    Hi Everyone!,
    My first post!
    I have a 1991 Mitsubishi Mighty Max 2wd with 250k miles on it.
    I could really use some help/advice. I have recently been told that I need to replace the lower control arm bushings in order to get a proper wheel alignment. They are shot so I do see the need to replace them.
    My first question is, what else would you recommend I replace as long as I'm down there? Like shocks, or other bushings. It looks like there are a few things that I may as well do as a preventive measure.
    My next question is, other than the Haynes manual (which I have), is there anywhere I can go for step by step instructions. I think I can do it with Haynes but I would like a back up if needed.
    Thanks and I really appreciate any help or suggestions you could give me.
    Los Angeles, CA
    So, can anyone give me any help please?
    WA
    Welcome! I'm sure you'll get some good advice shortly. At 250k, I would look at getting a complete bushing replacement kit and inspect your shocks before just replacing them. They're pretty easy to pop on and off to see if they still have a gas charge. Look for the Rock Auto discount thread on here.
    1990 MM 4x4 3.0
    1991 MM 4x4 3.0 Diamonte
    Los Angeles, CA
    Thank you. I will look for it.
    pa
    Welcome,
    Also with that kinda mileage I would inspect the power steering rack if you have one.
    you mean power steering box - none of these trucks are rack and pinion
    pa
    Correct.^ ps box
